    Nov 2009
    Default Garbage Disposal
    My garbage disposal spins and makes a lot of noise (it's not jammed) yet it doesn't really chop up the food and suck it down...it's about 25 years old...time for a new one? Or is it something that can be fixed fairly easy?
    6,055
    Default Re: Garbage Disposal
    I would say it's time for a new one. It could be the grinding wheel has worn out or the shaft has broken.
    Dec 2009
    Casper, Wyoming
    159
    I would definitely go for a new one. You can purchase and install one on your own for under $100. Lots of luck.
    ____________
    Find licensed plumbers in your area.
