Thread: wall tile
    Nov 2009
    Default wall tile
    is there and easy way of taking wall tile off without dameging the wallboard?
    Jan 2009
    Taxachusetts
    136
    Default Re: wall tile
    Not usually if it was installed correctly.
    Dec 2009
    Hello,
    digging out grout to get between two tiles, then just chisel under all the tiles from there and knock them down. You'll want to wear eye protection because of flying shards of ceramic, and lay a thick canvas tarp under the area so the falling tiles don't damage the floor.
    Dec 2009
    Casper, Wyoming
    159
    charlesedwin gives good advice here. I would like to add that you can use a a heat gun on low setting or even a hair dryer to help with the removal. Good luck!
    _____
    Networx.com
    We provide the latest information on how to fix, renovate, and decorate your house using the least amount of resources for the best value.
    Aug 2009
    62
    Removing the grout and chiseling is the best way of doing it without damaging the wallboard. However, your still probably going to damage it if you are removing it from an entire wall (mistakes happen). Is this a case of just needing to remove a row or a couple of damaged tiles? Or is it because you are retiling an entire area? If retiling an entire area you're better off just ripping down the wallboard and putting new wallboard or concrete board up, its pretty cheap to do and would save you a lot of time.
    Sep 2009
    florida
    598
    Im with Shawn, depending on the adhesive used from day one will depend if the sheetrock get any damage. You for sure to tear the paper if anything
    Gizmo
    Hidden Content
    Hidden Content
