Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 43
  1. #21
    Nov 2009
    Jersey
    7
    Default Re: Whoa, major electrical safety violations
    Quote Originally Posted by NEC View Post
    How is power cut to a single residential service?
    Well, lets see....if it feeds overhead, the power co eithers cuts it at the pole i.e. the individual service connection. Or at the house depending on what needs to be done. If the service is UG, it will either be disconnected in the transformer if it feeds from one, or a secondary enclosure, again only removing the service to the single customer.
    Master Electrician???????
  2. #22
    Nov 2009
    Jersey
    7
    I hugely disagree. I have done many a service change and have shunted the meter out. Three phase meters even have a handle and shunts built in. As long as I called the power company telling them I had a closed loop I have not had a problem in 30+ years.
    The utility I work for doesnt allow an electrician to bypass the meter. You call the power company, a crew shows up does the disconnect, you do your work, the crew returns heats it back up. Residential, $212 ripoff that the regulators allowed. Commercial 3 phase, depends.......
  3. #23
    1,387
    Howdy i cringed when the Electrician grabbed the live wires and strapping cable with a bare hand. Kids watch this show so shame on TOH...... Safety glasses are always referred to but is that the extend of their idea of safety... Boneheads! This needs to be addressed on a future program to warn kids to never touch these lines- including tall middle aged kids. Sudden death not addressed is sure more nasty then putting an eye out. otherwise. Shame Shame Shame.
    Lineman's gloves and caution to never grab these energized lines would of been the professional first heads up!
    Has that electrician never seen a short caused by worn insulation on wire? Man turn the channel....
  4. #24
    Shamokin, Pa.
    645
    Edge1289's post describes the process to a "T".
  5. #25
    Jun 2009
    Every place I have seen, for above ground service there is a fused switch on the pole. Takes about 30 seconds. VS if 2 of the wires had touched you would of had an arc flash that would have at least knocked both of them off the ladders. Melted all the exposed synthetic cloth. At least second degree burns most likely some time off work with burned hands.
  6. #26
    6,047
    The fused switch controls power to the transformer, in some places one transformer feeds multiple homes.
  7. #27
    Quote Originally Posted by rtparso View Post
    The switch for our utility feed is further upstream ( down the lane ) ---- so without knocking power out for about a dozen homes ---- how else would you do it ?
  8. #28
    Nov 2009
    Jersey
    7
    See my first post on this page.....
  9. #29
    Nov 2009
    Jersey
    7
    The fused switch is known as a cut-out box, it generally fuses transformers or primary branch circuits. Cut-boxes are not used to disconnect individual service connections.
  10. #30
    Feb 2009
    693
    Quote Originally Posted by Edge1289 View Post
    Ummm, yes I have a masters license. I was curious to how power was cut on a single residence when a transformer tap might feed multiple homes in different areas of the country and with different power suppliers regulations...... It goes beyond the NEC and is not really covered in NFPA-70E.
    I would say that a lateral cut to the home is no more safe either by an electrical contractor or the "Power Company" as long as I follow 70E.
    I would also say that fault current at a residence is seldom more than 10k and arc flash is minimal.
