    Nov 2009
    Default Insulating an Attic
    In my attic there is a blown in insulation between the ceiling joists which is somewhat packed due to the years of being there.
    I'm planning on adding faced fiberglass batts of an insulation.
    Should I remove blown in insulation , or is it OK to lay the batts with vapor barries across the ceiling joists without removing it ??
    Please help
    Brnslonce@aol.com
    1,387
    Default Re: Insulating an Attic
    do not remove any consider instead the easy method-simply rent a blower an add more Most anywhere you can buy insulation you can borrow or rent a blower.
