Results 1 to 9 of 9
    Question faucet & drain install update
    I had granite installed including a double bowl sink. I need a faucet and garbage disposal installed with new plumbing and waterlines. I have already posted this but since have two contractors give quotes, 1st for $550.00 the other for $350.00. What would be the difference and is either reasonable? And is the lesser amount quality work?
    6,115
    Default Re: faucet & drain install update
    Without seeing the quotes or knowing what needs to be done, how do expect us to guess?
    I agree with Jack, without seeing the quote and exactly what all is included in that quote, we cannot offer an opinion on the bids. Neither one sound too expensive for what you've brushed over, but again, without details, who know.
    Question Re: faucet & drain install update
    Both quotes are the same. Installation of moen faucet with 16" flood safe braided lines. Installation of in-sinkerator garbage disposal,new strainer for second bowl, plumb drain valves into p-trap pvc.Does this help?
    Feb 2009
    693
    I think the answer would be obvious.
    Are you sure you are comparing apples to apples?
    Do not understand, I guess, the question.
    .......... One of the plumbers could show up with a bent over butt crack showing and I guess you could throw 2 clams either way.
    6,115
    Do both quotes include the faucet and the GD? If so do both list the same model number. The price of different models of DGs could count for $200 difference same with the faucet. You also don't mention electrical.
    The garabge disposal and faucet was already purchased by me.
    Switch and electric is already there from old garbage disposal
    6,115
    A difference in hourly rate and the estimated time by each contractor could account for the difference. Remember they have to figure travel time also.
    Jack And one could have a helper and the other doesn't.
