Thread: Crater walls
    Nov 2009
    Default Crater walls
    We just purchased a home that has so much texture on it the wall could be dangerous. There a peaks more than 1/4 in depth and over 6 inches long all over the entire room and it appears it has been painted. Is there any way to dissolve the compound and if not, can drywall be installed over it. I'm afraid the drywall would make the room smaller but if that's the only alternative, I will be glad to have it done.:
    102
    Default Re: Crater walls
    If you cant sc**** it off. Then the best bet would be to demo it and reboard it.
    Aug 2009
    Ladson,SC
    192
    Quote Originally Posted by patrish81 View Post
    Check out this tool.
    EPF 1500 Scouring Machine.
    Concrete Tool Supply
    You will need a good shop vac also.
    Plus it will cost you somewhere around $ 450.00 / $ 500.00
    Does a supper jof and fast on plaster.
