    Nov 2009
    Post Noisy pipes when flushing?
    Once the toilet is flushed in our upstairs full bath, the pipes make this terrible fog horn sounding noise when filling the tank back. Please help?
    Nov 2009
    Default Re: Noisy pipes when flushing?
    Sometimes a faulty vacuum breaker on the water line will cause this
    Nov 2009
    The exact thing is happening in our house...in the upstairs bath, when you flush the toilet....15-30 seconds later a lound noise, kind of like a horn or muffled alarm is heard throughout the house. Did you confirm the cause of the problem? I am on the verge of calling a plumber.
    Jan 2009
    Taxachusetts
    136
    It's either the fill valve, replace with fluidmaster 200,(most likely) or there is debris lodged behind the shut-off valve to the water closet.
    Shaun
    Yup, a common problem with fill valves just replace the ballcock with a new fluid master and your good. Easy to do and fairly cheap.
    Here's a how to link: http://www.plumbinghelp.ca/howto_rep...fill_valve.php
    Plumbing and Heating Tech.
    My plumbing website Hidden Content
