    Oct 2009
    Exclamation Advise: Cutting open exterior wall for new door
    Hello,
    Looking for advice help with cutting open a whole in an exterior wall in order to install a new door. My project is to close one door up and install a new one on the other side of a window.
    Here are images from the inside then out.
    My thoughts are either to buy/rent a AllSaw AS170
    or renting a concrete chain saw like these
    and just cut the opening out and take it from there.
    Is there anything wrong in my thinking or advise/tips you could give? I'm guessing I need to install a lintel for something like this? And should I worry about the door being so close to the corner of the house?
    Any insite would be greatly appreciated.
    Default Re: Advise: Cutting open exterior wall for new door
    You can't just cut a hole in a block wall without supporting/resupporting the head area over the door. I'm not sure what the correct term is (lintle I think ) for this support structure, but I can tell you that it's necessary so that the integrity of the wall is maintained.
    May 2012
    12
    AllSaw AS170
    May 2012
    13
    Nice sharing by all of you my friends thanks for your sharing...
    Thanks,.
    2,743
    Sometimes DIY isn't a good idea unless you have experience and the tools for the job. You'd probably be much better of having a contractor deal with this one as you're going to need masonry, block cutting, framing, wall finishing, and Trim Carpentry tools and skills for this project. And you positively need a lintel over the opening or the block will eventually fall even if it stays in place for now.
    This can be a DIY project for an advanced DIY'er but with your asking which tool to use for a basic part of this project, I worry that this is past your abilities and I don't want you having problems later on. This is definitely an advanced level project!
