Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. #11
    Default Re: Odd ball plastic thingy....
    Rather than using plywood ---------- which might rot if wet ------- go to a dollar store and pickup a cheap nylon cutting board.
    They come in various thicknesses and shapes ----- round , square or rectangular.
    When you find one the right size ------ lay the old one down and trace it onto the new pice. Then lay on the new one ( the one that's too small ) inside the larger traced outline ----- trace out the opening and mark the screw holes ------ cut and drill and you're done.
    Looks as though there are 2 stand offs to deal with ------- you might be able to cutoff the old ones and expoxy ( or duct tape ) them to the new piece ----- then and again it may not be a big deal if they were glued in place.
    Just a thought.
  2. #12
    Feb 2009
    693
    I think there is a more simple fix. Just wad up a ball of duct tape and stick it to the wall. If you ever want to remove it use a little WD-40.
  3. #13
    Pennsylvania
    246
    Just a thought.
    damn...what's with you guys and duct tapes.....
    "Life does not go by the book, we learn as we go along".
    You only need two tools in life - WD-40 and Duct Tape.
    If it doesn't move and should, use WD-40.
    If it shouldn't move and does, use the Duct Tape.
  4. #14
    Pennsylvania
    246
    All of you need to go to Duct Tape Anonymous meeting.
