Thread: Staples
    Oct 2009
    Default Staples
    What is the best way to remove staples from a wood floor. I bought an old house and padding for the carpet was stapled to the floor boards.
    7,051
    Default Re: Staples
    There's usually bits of pad left under those staples, making it easy to grab them with pliers or get a flat screwdriver under them. I tend to prefer side cutters for most pulling chores because they bite a little better than pliers and they have better leverage.
    Oct 2009
    Default Re: Staples
    most of the staples are sunk into the wood any ideas.
    7,051
    Default Re: Staples
    Utility knife will get under tight staples easily enough. Loosen then grab with pliers or side cutters and pull.
