    Aug 2009
    9
    Default Cement Board or Float Wall
    I am in the process of tiling my small bathroom. I just had the base hot-mopped and was wondering if I should float the walls or use cement Board? Is there a big advantage to floating?
    OKC
    247
    Default Re: Cement Board or Float Wall
    The reason you might need to float is if the walls are out of plumb, or not square, otherwise you should be ok with cement board.
    HOPE THIS IS HELPFUL!
    Oklahoma City, OK
