I have a small area that I want to lay brick down where I keep the trash container. I have seen on some Home Improvement shows where they have used a plastic grid or form that is put down first then the brick is inserted into the grid with the proper space in between each brick. How easy are these forms to use and would you recommend them for the novice.
