    Oct 2009
    Old Brooklyn (Cleveland), OH
    Arrow How to remove wallpaper glue?
    We removed the wallpaper off our plaster walls. This is our first time working with plaster walls...What is the best way to remove all the left over wallpaper glue? Need some help...thanks!
    Sep 2009
    florida
    598
    Default Re: How to remove wallpaper glue?
    Start here there are many different ways.
    Ck youtube also
    http://www.google.com/search?hl=en&s...e+wall&aqi=g10
    Gizmo
    Hidden Content
    Hidden Content
    Aug 2009
    Ladson,SC
    192
    Use plain clear hot water no additives.
    Apply to the entire wall area wet thoroughly and leave for 30 min. than double back with more hot water and most of the glue should release from the plaster.
    As a last resort use a fine sanding sponge with hot water.
