    Oct 2009
    Dallas Tx
    19
    Default Door hinge - Odd size
    I'm in need to replace the hinges on two entry doors that were installed during initial build of the house in 1982. These hinges are not the typical symetrical hinge in that one half of the hinge is 1.5 inches wide and the other is 1.75 inches wide not including the barrel. The overall width is 3.75 inches. The height is 4 inches. The 1.75" side bolts to the door jam.
    See the attached two pictures. One picture shows the manufacturers' symbol that's stampped on the hinge. I can't find anyone that recognizes it. The symbol has a capital "P" and a small "d" underneath. I've asked the top 3 hinge suppliers found on the internet and they don't know who made it and they don't have a replacement for it. The other picture is a hand sketch of the hinge dimensions and approximate location of the screw holes.
    Does anyone know of a supplier or tell me who made these hinges? Thanks in advance
    Correction: The overall width is 3.75". Earlier I put 4.75. Attached is a corrected sketch.
ID:	2883   Click image for larger version.
    7,592
    Default Re: Door hinge - Odd size
    You might check VanDykes.com
    5,941
    You might want to check with Peachtree Doors.
    Oct 2009
    Dallas Tx
    19
    Thanks everyone. I'll call these shops today.
    Oct 2009
    Dallas Tx
    19
    The manufacturer was Peachtree Doors and Windows. I called them up and new hinges are on the way. Thanks again.
    5,941
    Glad it worked out for you, and thanks for posting back.
