Results 1 to 10 of 12
    Jul 2009
    19
    Default Are jumper grounded outlets safe?
    I've seen people run a jumper from the neutral terminal of an outlet to the ground terminal when working in older houses with only two wire systems and no separate ground available. I know it satisfies a tester to read that the outlet is properly grounded and even allows GFCI outlets to work. I also know that in many three wire systems the ground and neutral wires all go back to the same buss in the panel anyway. My normal practice has been to run a new ground wire at least to a cold water pipe or a rod in the ground depending on which is more convenient for the location. Have I been doing a lot of extra work for nothing? Is the jumper arrangement just as safe, and is it an approved (code) procedure?
    Old Tom
    Sep 2009
    jersey
    174
    Default Re: Are jumper grounded outlets safe?
    Quote Originally Posted by Old Tom View Post
    Old Tom
    NO, NO
    I need a maximum of ten charachters to post but there really isnt anything else to add
    Help us name our new Hidden Content
    Feb 2009
    693
    What Lloyd said................
    Both methods desribed are dangerous and far from code compliant.
    6,054
    Very little can be added to Lloyd's eloquent and definitive answer NO, NO.
    As a side note ground has nothing to do with the function of a GFCI. The GFCI compares the current flow in the hot and neutral and trips if they don't match.
    Sep 2009
    jersey
    174
    As a side note ground has nothing to do with the function of a GFCI. The GFCI compares the current flow in the hot and neutral and trips if they don't match.[/COLOR]
    right .. on the load side, thats what makes it ok to use a gfi where no egc is present, but that sticker doesnt really replace a ground. It really doesnt take much to pull a piece of thhn for an egc.
    Quote Originally Posted by Lloyd View Post
    NO, NO
    Quote Originally Posted by NEC View Post
    Ditto ..... Ditto ........ Ditto
    6,054
    Agree. I wasn't saying not to run a ground just correcting a statement made by the op "I know it satisfies a tester to read that the outlet is properly grounded and even allows GFCI outlets to work."
    Shamokin, Pa.
    645
    Old Tom
    It might satisfy a tester, but it should not satisfy an inspector.
    Jul 2009
    19
    Thanks everyone, you confirmed my suspicions. The thing that started me noticing this practice was when someone at a Home Depot sold a customer of mine some outlets he had wired jumpers onto for her. I'm just a general handy man, not a licensed electrician, so I wasn't sure.
    Old Tom
    6,054
    It's called "The Orange Plague"
