Thread: Sticky door
    Oct 2009
    Menasha, WI
    Default Sticky door
    My 40 year-old-plus house has metal door casing for all inside doors. My bedroom door is extremely tight on the latch side. Is there an alternative to shaving the hinge side and remortising the hinges?
    OKC
    247
    Default Re: Sticky door
    have you tried longer screws in the hinges? there should be a stud behind the jamb you could put one 2 to 3 inch wood screw in each hinge.
    HOPE THIS IS HELPFUL!
    Oklahoma City, OK
    Oct 2009
    Menasha, WI
    Hadn't thought of that. Will give it a try. Thanks
