Results 1 to 10 of 11
    Oct 2009
    6
    Exclamation Need help with old wiring
    Hi, I am doing some home renovations and I am replacing a fluorescent ceiling fixture with a much smaller halogen fixture. When I removed the fluorescent fixture the wiring was not like something I have previously encountered. It was much older than what I have seen before. I should note that the frame from the fluorescent where the wiring runs through is still up. Anyway on one side there are two fabric covered wires coming out one covered in white with black “spots” and the other white with red “spots” One more wire coming from the other side is solid black. Which ones are my neutral, hot and ground and do I need to connect them differently to the newer halogen fixture because of how old they are?
    I should also note that there is a wire coming out of the side with the other two colored wires and it connects in the middle of the fixture with another wire coming out of the side with a black wire.
    Also the house was built in 1918
    Thanks for your help!!!
    Sep 2009
    jersey
    174
    Default Re: Need help with old wiring
    Quote Originally Posted by dschultz91 View Post
    What country are you in?
    Help us name our new Hidden Content
    Oct 2009
    6
    United States, Wi
    Sep 2009
    jersey
    174
    That that you have so many individuals wires coming from different directions suggest it may be knob and tube, but cant say i ever saw polka dots on knob and tube, probably gonna need some pics to get specific.
    Oct 2009
    6
    ok i will try to get some on tonight already
    Oct 2009
    6
    Pictures of what I'm talking about
ID:	2844   Click image for larger version.
ID:	2845   Click image for larger version.
ID:	2846   Click image for larger version.
ID:	2847   Click image for larger version.
    Oct 2009
    6
    more pictures
ID:	2849   Click image for larger version.
    6,114
    Can you see where the 2 cables go? How were the wires connected to the old fixture?
    Sep 2009
    jersey
    174
    looks like theres another fixture near by being fed off the other conductor, i'm guessing.
    Oct 2009
    6
    o yes that makes perfect sense there are 3 more fixtures just like it on the same breaker. So should i leave the one running through the fixture how it is? which is my hot my ground and my neutral?
