    Oct 2009
    Default Floor insulation upside down/reversed
    I just received a home inspection noting floor insulation is installed upside down- the vapor barrier toward the ground rather than toward the living space. There were no adverse conditions noted, but I imagine mold or mildew might be possible if it were not "breathing" properly.
    Has anybody had experience with problems caused by incorrect installation? Should it be fixed, or can it be left alone? Any comments are appreciated!
    Sep 2009
    florida
    598
    Default Re: Floor insulation upside down/reversed
    Quote Originally Posted by dalecrockatt View Post
    Is this in a crawl space ? If so read the link below.
    http://energyaudit-sdge.sempra.com/library/basement.asp
    Gizmo
    Hidden Content
    Hidden Content
