    Oct 2009
    Minnesota
    Default Replacing Old Heat Diffusers
    I need to replace my 4ft Heat diffusers- I'm getting new carpet installed in two weeks. Upon removing the old battered diffusers, it appears they were installed and then the old carpet was installed making it impossible to remove the old diffusers without taking the carpet up. Is this correct? My other question is: Where can I find 4ft Heat diffusers? Home Depot etc, have 2 ft diffusers- haven't seen 4ft ones. Any idea's? I would like to stay away from white but it appears that might be my only option!
    Thanks!
    Jen
    566
    Default Re: Replacing Old Heat Diffusers
    Heat diffusers are available at heating supply houses in your area---consult the Yellow Pages under "Heating-parts" for a list of dealers in your area.
    Make sure to bring one of the old diffusers with you when you shop.
