    78
    Default Stained Wood Panels
    At some point in the history of my 1940's house, there was a water problem in the basement. My guess, a water heater. Anyway, the panels in the basement in one area are stained at the bottom. I took the base molding off, and scrubbed after sanding off the finish. Then applied a paste of oxalic acid. Left if for a few hours, Then washed off the wood bleach. Tuns of yellow water. Still there's a quite dark stain. When the wood dries, if shifts to a light grey which would be ok, but not perfect. I tested a touch of shellac with a vintage amber tone to match the rest of the wall, and the stain comes out dark again. Before I give up with this and put a much taller base board on, is there something else I can use to cover the stains before finishing? Maybe some sort of paint or something?
    78
    Default Re: Stained Wood Panels
    Yeah, that's a great article. I read that before my start. I've applied several coatings while allowing the panels to dry. My bleach of choice is oxalic acid, since I thought the stains might have been iron based since they are a greyish black, that turn quite dark black when finished.
    I had a thought the other day that I may try. I was thinking of sanding the space down, lower than the rest by 1/8th to 1/4 of an inch and filling with pine colored wood putty to cover the stained area.
    I thought this might be a work around to a tough stain. If all else fails, I'm just going to put on a taller base board. It will look kinda strange to have a 12 inch base board on a curved wall, but it will look better than black stains.
    OKC
    247
    Have you tried thinning the stain at the bottom to try to even it out?
    HOPE THIS IS HELPFUL!
    Oklahoma City, OK
