    Oct 2009
    Default crack in a sheet rock ceiling
    Have a 1960's ranch with a open celing between kitchen,dinning room,& living rooms that has a major crack in it have checked in attic and no structor damage that can be seen.What is the best way to repair.
    980
    Default Re: crack in a sheet rock ceiling
    the crack is probally on a joint between sheets, put a piece of wood running along the crack on the backside and screw into place tying the two side together and refinish the face of the rock like you would a normal butt joint.
