    21
    Default cold water abruptly shutting off
    I have a utility tub in my basement and lately when I turn on the cold water it will turn right off. I can usually get the water to run after turning on and off a few quick times, but obviously this is ridiculous to have to keep doing. The faucets are very cheap (like $20) but before I buy one, is this a faucet problem like I assume...? maybe an issue with a washer or the control valve/cartridge itself?
    thanks
    7,914
    Default Re: cold water abruptly shutting off
    It is likely a problem with the cold side of the faucet valve. If the faucet is a relatively decent one, then rebuilding the valve will be cheaper and easier than replacement. If it's a seriously cheap faucet, then I'd change it out for one of a better quality. I personally like Delta and Pfister the best. Stay away from faucets that are all plastic, they don't last or function well for very long.
    21
    Thanks, it appears to be there for a very long time, so I'll most likely replace it. Not worth trying to rebuild it if I can find one for $30.
    appreciate the feedback
