    Oct 2009
    Central NJ
    Default Strainer Basket & Drain Removal
    Hi,
    I have a house from the early 1930's but I'm not sure if this is the original fixture or not. The drain on my double slop sink was backed up and in the process of cleaning the trap broke. I have attached images of the strainer, the drain below the sink and the ring and adapter used to connect the old drain.
    I was thinking that I could replace the strainers and drain with PVC but I'm not sure about the best way to remove the old ones. I was thinking about cutting the drain which hopefully should release the strainers. Unless there is a tool available to remove the strainers as there is no nut under the sink connecting the strainer to the drain as found on newer sinks.
    Any suggestions would be greatly appreciated.
    Thanks,
    Ryan
ID:	2823   Click image for larger version.
ID:	2824   Click image for larger version.
    Default Re: Strainer Basket & Drain Removal
    Looks like it's similar to that of a tub drain strainer.
    You might try what's called a " dumbell "
    Oct 2009
    Central NJ
    Thanks Canuk
    You're welcome .
    Let us know how you make out.
