    Sep 2009
    9
    Default Wiring around a corner
    I am remodeling my master bedroom right now and currently I am down to studs. I started wiring today and ran into a problem. I have to turn a couple of corners on two seperate runs. How do I turn the corners? I cannot figure it out...
    OKC
    247
    Default Re: Wiring around a corner
    have you tried drilling from both directions?
    HOPE THIS IS HELPFUL!
    Oklahoma City, OK
    Sep 2009
    9
    I have from one side but cannot fit my drill in from the other.
    OKC
    247
    you might have to buy a flexible drill bit, they are a couple of feet long and the shaft is flexible so you can get it in tight spots.
    Oklahoma City, OK
    Sep 2009
    9
    I just got it. I forgot about using my impact drill. Used that as it was shorter than my regular drill. Thanks for the help.
