    Oct 2009
    Unhappy Vintage wood sliding door
    I have a vintage wood sliding door that i cant open. Previously i would just close it halfway and it would slide back but the first time i closed it all the way it wont slide back now.
    5,789
    Default Re: Vintage wood sliding door
    You may have slid it to far and the back rollers exited the track. You can sometimes just pull on the top of the door while holding the bottom and get it back on. Other wise you would have to remove the trim to get it back on.
    Or you may be in and hitting on the side, in which case you can pry the door over a little to get it to clear.
