Results 1 to 10 of 12
    Jun 2009
    19
    Default Running Feeds into Main Service Panel
    Hello All,
    I am running 17 feeds to my 200 AMP service panel in the basement. The panel is a 200 AMP Cutler-Hammer panel. There are several holes on the top of the panel for the cable clamps however there is not enough to support 17 feeds each having their own entrance hole. So my question is: Is it allowed to have more than one feed enter the box through the same hole/cable clamp?
    Thanks,
    Chris
    Feb 2009
    693
    Default Re: Running Feeds into Main Service Panel
    Just check the listings on the clamps you want to use.
    Shamokin, Pa.
    645
    Quote Originally Posted by christech View Post
    Hello All,
    Thanks,
    Chris
    An allowable practice to is use a 3/8 Romex connectors with two 12/2 feeds passing though.
    I did think I read where in is not allowed in Canada, though.
    Any thoughts on that?
    Jun 2009
    19
    Ernie,
    Thanks for the clear reply.
    Also, thanks NEC, however I find myself scratching my head when I read some of your replies.
    Regards,
    Chris
    Feb 2009
    693
    Ernie,
    Regards,
    Chris
    Thanks!.........
    Shamokin, Pa.
    645
    Quote Originally Posted by NEC View Post
    Thanks!.........
    I scratch my head when I proof read my replies. An analog man in a digital world.
    Feb 2009
    693
    You put it well.
    Sep 2009
    jersey
    174
    Way to make it confusing ... using words like check and clamp ... pffft
    Help us name our new Hidden Content
    You put it well.
    Here .. Here
    Jun 2009
    19
    Quote Originally Posted by Lloyd View Post
    Lloyd,
    What does one check for on the cable clamp? Does the cable clamp specify the number of wires allowable through the clamp? Overall, is there a limit to the number of wires that I should run through the hole in a 200 AMP box? For example, if I run a 3 wire 12/3 and a 12/2 will I get flagged by the inspector? What's your experience?
    Thanks,
    Chris
