    Sep 2009
    Default exterior paint mold
    Has anyone else had problems with Sherwin Williams Duration exterior paint molding, flaking after only 2-3 years? The north side of house is fine, the sunny side, painted a year later, is awful!
    Sep 2009
    florida
    598
    Default Re: exterior paint mold
    Have one of S&W's reps come out and look at it. They should have the answer. Most any S&W store have reps,there all happy to help out the customer. It makes no difference if your a contractor or homeowner as long as you used there product.
    Sep 2008
    Fargo, ND
    144
    These kinds of things are rarely the paints' fault...
    It's usually a prep (or LACK of prep) problem, moisture out-migrating through siding, not priming when it should've been done, dirty siding, not testing a wood siding for moisture......and on & on....
    Usually the sunny side has peeling first!
    The sun warms surfaces, and moisture naturally wants to exit to a warm surface, thereby pushing-off poorly adhered coatings.
    The quality of a home's insulation can be part of this issue.
    Sometimes "hack" painters thin out a coating waaay too much...
    There's a thousand variables here...some of them invisible!
    >>> Are there any details about the siding/insulation/prep that you can find out??
    Faron
    Oct 2009
    west virginia
    Thumbs up Re: exterior paint mold
    start with srubbing this wall with a scrub brush and a bucket of water , bleach, and TSP, rinse. If you still don't like it repaint. this time use a mold retardant in the paint. Don't paint when the sun is on the wall, it drys to fast before the paint can soak in and make a bond.Barb
