Thread: Tub Overflow
    Default Tub Overflow
    Hi, I have a tub overflow that is stuck and won't close, When trying to remove the screws that hold the face cover on the tub one of the screws broke from rust. Did not remove the other one yet. My question is how can the broken screw be replaced? There is no back panel to the tub to remove the broken screw.
    Jan 2009
    Default Re: Tub Overflow
    You can try an easy out or screw extractor or try to just drill it out. Slow and steady wins the race. Loosen with some penetrating oil first, just be careful of the tubs finish.
