    May 2009
    6
    Default Help! Large hole in outside wall.
    I just noticed a pretty sizable hole on the exterior corner of our foundation. The hole is right where the wall meets the ground. The wall is concrete block, and, while the hole is deep, I cannot see it from the inside of the basement. It is in the same corner as our electrical board. This corner has also been pretty leaky. What should I do? Should I patch it with hydraulic concrete or call in the pros?
    Sep 2009
    florida
    598
    Default Re: Help! Large hole in outside wall.
    Can you attach a picture
    May 2009
    6
    I'm working on loading pictures. It looks like the hole is where mortar eroded away.
