    Sep 2009
    Default linear shower drain
    we're remodeling to make bathroom handicap accessible. want to make the shower completely barrier free w/ ability to roll in on 2 sides. want the floor of the shower same as bathroom floor. how is floor sloped using a linear drain?
    will probably use marble tile.
    thank you
    Arlene
    Jun 2009
    The Great Lake State
    22
    Default Re: linear shower drain
    There are quite a few of these drains now available in the U.S. market. You may need to use some different search terminologies to find all the different manufacturers.
    One result from Google is the FreeStyle Linear Drain:
    http://www.noblecompany.com/Products....aspx#products
    Texas
    128
    You want to install the drain about a half inch below the level of the floor, then from about 6 inches outside the shower curtain slope to it. May be easiest if the drain is along one wall only. Still need to have a trap in the line out, as close to the trough as possible.
    Mar 2011
    5
    Want to make the shower completely barrier free w/ ability to roll in on 2 sides. want the floor of the shower same as bathroom floor.
    3,117
    The thread is a little old to be giving her some answers no?
    Mar 2011
    10
    I bet you will get the same if you flush the toilet as well,
    This is known as cold mains pressure over riding the hot.Cured by popping a PRV on the Cold supply pipe work.
