Thread: Door Step?
    Sep 2009
    Default Door Step?
    I hope someone can help me. I want to change the step that you stand on when you enter my home. I am not sure what it is called. It probably is made of OAK or some other hard wood. When I went to hardware store they didn't know what I was talking about. I now took a picture and am sending it with this post. I know what the threshold is and it sets on top of this part.
    See photo,
    Thanks
    Marv
    Sep 2009
    florida
    598
    Default Re: Door Step?
    It's the door sill,look at the link below.
    A door sill forms the bottom of the frame at an exterior doorway and serves a function similar to a windowsill it serves as a durable base that diverts water away from the door and house. The sill fits snugly under the casing and against or under the jambs.
    Fastened to the sill is a threshold, which helps seal the air space under a door. Thresholds are often used in interior doorways, too, to cover a transition between different flooring materials.
    http://www.lowes.com/lowes/lkn?actio...Threshold.html
    http://www.hammerzone.com/archives/l...s/sill_rot.htm
