    Sep 2009
    Ohio
    Default Tighten up Shower Head
    I have an old porcelain shower head. The male threaded part is loose. How do I tighten it so it wont leak?
    Thanks in advance.
    Allen
ID:	2806   Click image for larger version.
ID:	2807   Click image for larger version.
    Jun 2009
    The Great Lake State
    22
    Default Re: Tighten up Shower Head
    I dont know --maybe epoxy ???just thought Id keep this moving!!
    Sep 2009
    Ohio
    Smile Re: Tighten up Shower Head
    Took the plunge and decided to try and take the Head apart.
    If anyone is interested I can post pictures and discuss the procedure. There are a few things to watch out for.
    But was able to get it taken apart, cleaned up and made a new gasket. Now Shower Head is tight again.
    Wisconsin
    80
    Hello, good job! If ever loose again or need a little better seal this is what Teflon pipe tape is for. This not only helps you get a tighter seal it also seals itself. Job well done. Have a good day.GregC
    Hidden Content GregC, President/Founder of Hidden Content
