    Sep 2009
    Default Four fluorescent light fixtures fail in a row
    I'm using 48" T12 wide spectrum bulbs.
    The box says either T8 or T12 bulbs, but something inside keeps dying. The bulbs still work in other fixtures.
    The fixtures work for awhile, then just stop. Won't restart. Swapping out bulbs, turning off and on, replugging, changing wall sockets, nothing seems to work. Burned through two brands from two stores.
    Any idea what would be causing this?
    Feb 2009
    693
    Default Re: Four fluorescent light fixtures fail in a row
    Bill, Bill, Bill...... Change out to electronic ballasts and T-8 lamps....... It will equal better sleep.
    Shamokin, Pa.
    645
    Quote Originally Posted by Bill Haywood View Post
    I have been told that even thought they will fit in the same " tombstone" T12s & T8s are not interchangeable.
    Any thoughts?
