Results 1 to 10 of 11
    Sep 2009
    Burlington, MA
    6
    Default Installing a New Thermostat
    I want to install a new thermostat, digital or manual, I don't care what type at this point. I have tried both.
    If it helps to know- I have an electric heating system, one zone, with a register.
    I have 4 wires inside the electrical box. 2 whites which are twisted together. 1 black. 1 red.
    I have tried a 2-wire digital thermostat that had two black wires coming out of it. I tried connecting that and the thermostat kept resetting itself. Thinking it was just a faulty unit I bought two more... same problem.
    I then went manual. I bought a 4-wire thermostat. That had 2 red and 2 black wires. I tied the 2 red wires to the red wire in the electric box, and the 2 black wires to the black wire in the electrical box... nothing. Then I tied the black/red and black/red of the thermostat. I twisted those with the black and red wires in the electrical box and the heat turned on, but wouldn't turn off.
    I am sure I am not explaining it clearly, but I tried my best.
    What am I doing wrong!!!
    Jul 2009
    Northeast
    661
    Default Re: Installing a New Thermostat
    My addition has Electric Baseboard with a manual stat and the blacks go to blacks and whites to red, if you use a programable type there is a dip switch under the cover that should be on HE for electric heat. Good Luck!!!
    Feb 2009
    693
    The wiring does not sound quite right. A single black and red and yet two whites? Sounds line voltage as well so you would fry a low volt stat in a heart beat.
    Can you post a picture?
    Sep 2009
    Burlington, MA
    6
    Quote Originally Posted by Sten View Post
    What should I do with the red? Leave it alone?
    Sep 2009
    Burlington, MA
    6
    Quote Originally Posted by NEC View Post
    Here you go. Let me know if the quality is good enough.
    Feb 2009
    693
    Tie the lower left black to the upper right red and tell me if the heat comes on.
    Sep 2009
    Burlington, MA
    6
    Yes. That turned on the heat.
    6,016
    I would say you need a 120v 2 wire thermostat. One wire to lower black, one wire to red.
    Sep 2009
    Burlington, MA
    6
    I tried a 120v 2-wire, however it was digital. Would that make a difference? Should I try a 2-wire manual? I couldn't find one in Home Depot, I haven't tried Lowes yet.
    Jul 2009
    Northeast
    661
    Shouldn't matter as long as its not a low voltage stat, like NEC said it will fry it in a heartbeat, red to red black to black, don't let any smoke out. Good Luck!!!
