Page 2 of 2 FirstFirst 12
Results 11 to 11 of 11
Thread: tub and shower
  1. #11
    36
    Default Re: tub and shower
    Hi,
    We have the tub and surround in!
    We even have the plaster off of the walls, and insulation in the outside walls. I am attaching a picture.
    Now, I have a question about covering the flange. The flange goes around the top of the enclosure, and down each end of the enclosure. Since the flange will be away from water (not on the walls inside of the tub), do we use greenboard to cover? We were thinking greenboard at least on the ends going down. But, what about around the top? Also we were thinking of using the same wood molding that will go around the top of the wall next to the ceiling. Do you have any ideas?
    Thank you! Maggie
Name:	DSCN2304 TOH 2.jpg
