    Aug 2009
    Default Odd Old Radiator Question
    I'm renovating a kitchen in a 1968 Long Island apartment. In the wall behind the sink cabinet, behind the plumbing, is an old radiator that was wrapped in a blanket of insulation when we did the demolition. Basically, the question is what purpose was the insulation serving, and should I replace the insulation?
    Photographs of the radiator (without the insulation) are attached.
    The insulation was quite old (appeared to be black, but when I took it out it was yellow/pink). Also, the insulation was only wrapped 3/4 of the way around the radiator, with the side facing into the kitchen largely exposed. Behind the radiator is the exterior wall of the building.
ID:	2783   Click image for larger version.
    Midwest
    181
    Default Re: Odd Old Radiator Question
    If it was just on the back side I would say it was to reduce heat losses through the exterior wall. Since its on three sides, it is to significantly reduce the heat output of this convector.
