    Sep 2009
    5
    Question New construction what is the best septic system for 4 people?
    You would think someone would have million dollar idea to improve septics? I have questions around initial cost and ongoing maintenance?
    1,673
    Default Re: New construction what is the best septic system for 4 people?
    Quote Originally Posted by bcrame View Post
    The Government does:
    http://blogs.abcnews.com/johnstossel...-outhouse.html
    1,717
    Too bad more people in the news & government don't think a little more like John Stossel.
    Septic systems are pretty much governed by local codes. Probably 1000 gal or more. Get it pumped on a regular basis according to its size & usage. Every couple years usually. A local septic company will recommend a schedule.
    I haven't priced one recently, but it will depend on the type required.
    It still beats an outhouse at any cost, but if it cost close to a million bucks I might change my mind.
    1,673
    The septic design depends quite a bit on the soil and the lay of the land. To begin with, you'll need to dig a couple of test pits in the area where the drainfield will be, for a "perc test." This is a soil analysis to determine how porous the soil is. It is usually conducted by the local authority in charge of regulating septic systems. They will then give you the requirements for the septic system for your site, but they will probably stop short of designing it for you. You will need to present plans to the local authority that meet the requirements they set forth for your site in order to get a permit to build the thing.
    (By the way, in a standard septic system, solids are separated from the liquids in the septic tank by microbial action and settling. Only liquid is supposed to flow to the drainfield, which disposes of the liquid more by evaporation than infiltration to the groundwater supply. If solids are permitted to enter the drainfield they will plug up the soil, which will require replacement of the drainfield in a different location. Septic tanks must be periodically pumped to remove the insoluble solids.)
    Some other considerations besides soil permeability include the locations of nearby water wells, cut banks, groundwater, and streams.
    Anymore, you can't just throw in a drainfield for a few hundred bucks, and there isn't a basic system that fits in most cases. Plan to spend some money on engineering by a qualified, licensed septic installer or engineer. For some strange reason, your neighbors are concerned for their health and quality of life, and an improperly designed septic system can be a major public health hazard. That's why the regulations on septic systems are so stringent, and that's why septic systems can be expensive to install. You can get an idea of what the cost might be by talking to neighbors with similar land who've had a septic installed in the last five or ten years (adjusting for the state of the economy, of course). Regulations haven't changed too much in that time frame.
    1,673
    P.S. -- If you have any groundwater above the bottom of the septic tank, fill it before backfilling. Otherwise, it just might float right out of the ground.
