    Sep 2009
    Default Hot mixing with cold water in Bathroom
    I have been experiencing problems in one of my bathrooms. When the shower is first turned on it is hot, within 30 seconds it gets cold. I have hot water mixing with cold water in the toilet, and hot water mixing with cold water in the cold water side of the sink. When I shut off the hot water supply to the bathroom, I get cold water coming out of the hot side of the sink. There has been nothing changed in the bathroom within the last five years. Only changes recently has been a new furnace (1 1/2 years ago,coil hot water heat)and new water meter installed by Water Division.
    Jul 2008
    San Francisco , Ca
    43
    Default Re: Hot mixing with cold water in Bathroom
    a new shower cartridge should remedy the situtation
    Pennsylvania
    246
    Quote Originally Posted by djrenek1 View Post
    would that fix the hot water mixing with cold in toilet and sink? I think there is more to it......
    "Life does not go by the book, we learn as we go along".
    You only need two tools in life - WD-40 and Duct Tape.
    If it doesn't move and should, use WD-40.
    If it shouldn't move and does, use the Duct Tape.
    Sep 2009
    The new cartridge solved the problem, Thanks!
