    Apr 2009
    Default Water pressure new shower install
    I am installing a new bathroom and really want to intall a three head system, the main head being directly above and two sprayers, one/each side. My problem is how to deal with the reduced water flow that will result when I open the side spray valves? Just reduce pipe diameter to the heads or am I going to have to have an additional or bigger diameter main run to the house and then reduced? Is this job doable or am I going to have to settle with one head?
    Apr 2009
    Default Re: Water pressure new shower install
    Bump. Nobody?
