    Sep 2009
    Default Painting Paneling
    I have purchesed and older mobile home. It has paneling on the wall. I am trying to decide the best way to paint the walls.
    Can you give me some suggestions.
    Irv
    1,387
    Default Re: Painting Paneling
    Howdy, primer for adhesion and color bleed works great. Kills oil base works great if ya spray it but lots of fumes and hard to roll on.
    8,065
    Actually, a BIN primer is better for stain blocking, still kinda smelly, but blocks staining very well. Read the label of the primer you use for proper cleaning methods, BIN primer requires alcohol to clean up, Kilz requires paint thinner. Kilz2 is a latex that cleans up with water.
    This is BIN primer.
    http://www.zinsser.com/product_detail.asp?productid=10
    8,065
    Tim, go into your profile and activate your Private Messages and PM me.
