    Eden, NC
    285
    Default Remove Hair Spray from a painted wall
    In the home we just bought, the previous owners apparently used hair spray quite liberally in the master bathroom. It gives off a dull appearance on the wall. Does anyone know a way to cut through the hair spray and clean it from the painted wall, or should I just paint over it? Your help is greatly appreciated.
    Calcats
    7,195
    Default Re: Remove Hair Spray from a painted wall
    Hairspray is water soluble, so you should be able to rinse a good portion of it off with a wet rag. To save yourself a bunch of labor I'd do a test with primer and paint to see if it will adhere, which it should.
    Eden, NC
    285
    Wink Re: Remove Hair Spray from a painted wall
    Thanks A.Spruce, your help is appreciated.
    Calcats
    7,195
    Can I have my cookie now?
