    21
    Cool How to remove old drain and linkage
    My old tub has an old steel drain and broken linkage. How do I remove the linkage and how do I remove the drain from the bottom of the tub. It is steel and seems to be set right in there for life. I would like to replace it with a pop-up stopper but for the life of me I can't figure out how to get the old one out. Does it unscrew so that I can screw in a new pop-up unit? If so, how do I get it started. This is an old but very functional and clean tub - I have put in a new tub surround etc., and this is the last piece I am fighting with.
    5,827
    Default Re: How to remove old drain and linkage
    Your tub drain assembly probably looks similar to this . Some have a nut that turns on the drain basket but others you need to turn the whole short pipe assembly and unscrew it from the drain basket.
