    Jun 2009
    19
    Default Calculating Wires Allowed in Electrical Boxes
    Hello All,
    I'm trying to determine if any the boxes I've wired have too many wires. I am using all plastic boxes and 12 gauge NM wire with no clamps. This is how I'm calculating the allowed number of insulated wires allowed for the boxes I'm using. Please let me know if my method of calculating allowed insulated wires is correct??
    Example 1:
    Double Gang Switch Box (34 CUI) --> 34/2.25 = 15 wires allowed. Now subtract 1 wire for the ground & 2 wires for each switch (2*2 = 4) = 10 insulated wires allowed.
    Example 2:
    Single Gang Switch Box (22 CUI) --> 22/2.25 = 9 wires allowed. Subtract 1 ground - 2 wires for the switch = 6 insulated wires allowed.
    Example 3:
    Ceiling Box (25 CUI) --> 25/2.25 = 11 wires allowed. Subtract 1 for ground = 10 insulated wires allowed.
    Thanks,
    Chris
    5,997
    Default Re: Calculating Wires Allowed in Electrical Boxes
    See attached
    Jun 2009
    19
    JLMCDANIEL,
    None of my boxes in the table you posted correspond to the box CI's I have installed. Is my calculation based on the box CI correct?
    Regards,
    Chris
    5,997
    Yes, your calculations appear to be correct for the CUI you listed.
    1,387
    Howdy, Are you including the ground wires in your rule of thumb? And are ya counting the wire nuts?
    Shamokin, Pa.
    645
    Quote Originally Posted by Timothy Miller View Post
    Remember to include the devices when you calculate your total.
