    Sep 2007
    Default sewer drain leak
    need info on resolving pinhole sewer drain leak under slab. all traps have been sealed and systems fails 5 lb leak test. pipe is 3" pvc. do not want to dig up slab to locate leak. this is needed to gain rough inspection approval. alternate method (water level) also fails. will consider relining methods. house is located near colorado springs, co
    Sep 2007
    Montréal, Qc, Canada
    19
    Default Re: sewer drain leak
    Check out http://www.rotorooter.com they do sewr relining
