    Aug 2009
    Default Replacing Motor on Bandsaw
    I need to replace the 1/2 hp 1725 rpm motor on my old Delta-Milwaukee band saw. Can I put on a 1hp 1725 rpm instead? Thanks!
    6,077
    Default Re: Replacing Motor on Bandsaw
    You can if it will fit, but don't over work the saw. The bearings and bushings where designed for a HP motor.
