    Aug 2009
    Default Kitchen Cabinet hardware
    Is there any general rule that says you should pick the same finish on the kitchen cabinet hardware as the hardware on your doors and windows? Someone says if you have oil rubbed hardware on the doors, you must follow suit. I had never heard that before. I guess I want to hear what you all would think. Thanks.
    Feb 2009
    693
    Default Re: Kitchen Cabinet hardware
    Anything less would look really, realllly bad. Just think about it.
    Aug 2009
    30
    Quote Originally Posted by NEC View Post
    I don't agree at all. It depends a lot on the size of room you're dealing with. The larger the space, the less necessary it is to use matching hardware.
    Also many really high end kitchen use different finishes in them. In fact, I was on a home tour this weekend, the value of the home was 1.8 million, and the door hardware didn't match the cabinet hardware.
    I would say it is most important to make sure they compliment each other.
    2009 kitchen remodel warrior
    asbolute black granite
    Antique White Hidden Content
    Travertine 18" x 18" floor tiles.
    It looks Great!!
