    Aug 2009
    9
    Default Shower pan slope
    The drain in my shower is 18" from the wall. How much mud should I use to make the slope. How thick should it be?
    Jun 2009
    The Great Lake State
    22
    Default Re: Shower pan slope
    it should slope 1/4" per ft.toward the drain.The thickness at the drain is dependent on the type of membrane you plan on using ,and the drain itself.
    The slope needs to be under the waterproofing membrane. If doing a thinset membrane (ansi 118.10) and the drain will go low enough your looking at a min 3/4" at the drain in most cases.
    Take a peak at the videos at www.noblecompany.com ,two methods FULL MORTAR BED using a standard CPE liner and THIN SET METHOD using a ANSI 118.10 thin set membrane.
    Aug 2009
    9
    Thank you. I was thinking of using Hydro Ban ad the water prooofing membrane.
