Thread: brass
    Aug 2009
    Default brass
    how can I clean and finish the brass on a metal bed?
    6,614
    Default Re: brass
    Brasso is a good general purpose cleaner.
    1,609
    Default Re: brass
    I would second Spruce's recommendation of Brasso. However, most brass has been sprayed with a protective coating to forestall tarnishing, usually a type of lacquer. You might want to wipe down the brass with lacquer thinner to remove the coating first, It will save you alot of extra rubbing. Brasso is basically a fine rubbing compound in a liquid form.
