    Sep 2007
    Default How Do I cut a mitered return on crown molding?
    How Do I cut a mitered return on crown molding when I have used 2 pieces. I have used an inverted 3 1/4" baseboard against wall surface, then I have a 4 1/2" cove. PLEASE HELP!
    Chicago, IL
    162
    Default Re: How Do I cut a mitered return on crown molding?
    First cut a return on the inverted baseboard, then cut a return on the crown, wrapping it around the return of the baseboard.
    HTH
    Dave
    8,065
    What Dave said, though here's a tip:
    Cut the miter on a long piece first, then cut to length. That way you'll have something to hang onto safely while doing all the cutting.
