Thread: Painting
    Aug 2009
    Default Painting
    Painted my front door & jam. hw can I get the door from sticking
    Its been over a month.
    Georgia
    150
    Default Re: Painting
    You need to find out exactly where it is sticking. There wasn't enough room between the door and the jamb for the paint. This is a common problem when painting doors and windows. I think you need to remove the door and plane the edge that is sticking. Then you can repaint. The section that is sticking should have a rubbed off area. If you don't have a plane you could also use a sander.
    Apr 2009
    158
    Do you mean the paint hasn't dried?
    What kind of paint did you use, and on what type of door (metal, wood)?
    Did you use oil base on metal?
    1,950
    Trent,
    If you used a latex or acrylic paint on your door and that painted surface makes contact with the weatherstripping, you are experiencing one of the down sides of acrylic paints - they never dry hard, retaining a "gummy" feel which gets worse in humid weather. If this is the case, there is not a whole lot you can do. If it is a light color, you might try a little talc powder where it makes contact.
    It is because of this gummy quality that I do not use latex paints of fine woodwork or furniture.
